Just got my speedohealer....
Old 11-03-2005 | 04:20 AM
Funkdock's Avatar
Default Just got my speedohealer....
What are the stock sprockets at as far as teeth etc?
Im not sure what my aftermarket sprockets are at Ill have to take off the cover on the front this weekend to count them and the back too. The sprockets were on when I bought the bike. All I can say is that its an 04 636 and the sprockets are an anodized blue color and a blue chain is on there too.
Any helpfull advice to put this thing on would be good too.
Old 11-03-2005 | 04:50 AM
ryninger's Avatar
Default RE: Just got my speedohealer....
they should be marked somewhere on the sprocket.... Why do you need to know?
Old 11-03-2005 | 05:02 AM
Funkdock's Avatar
Well isnt that info needed to set up the speedohealer? I havebt cracked open the box yet. NO till weekend
Old 11-03-2005 | 06:52 AM
Notstock's Avatar
You have to count them no matter what and you need to know the stock size as well. Here is a place where you should be able to get the info. http://www.kawasaki.com/product_deta...tag=motorcycle
Old 11-03-2005 | 12:36 PM
ryninger's Avatar
You shouldn't need the sizes to determine your speedo error. To determine your speedo error you will have to get the ratio of shown mileage/actual mileage. It is easy to do, esp on an interstate/freeway. Stop right next to a mile marker and reset your trip odometer, ride for about 20 or 30 miles. The longer you go the more accurate you will get. For example I went 60 actual miles, and my odometer showed 69.4. 69.4/60 = 1.1567. That is the ratio that I need to have the speedo healer adjust mine. If you have a gps system you can do the same thing.
Old 11-03-2005 | 01:53 PM
gotrice's Avatar
you do need to know the sprocket size to use the speedo healer calculator. Its the best way to go. It makes adjusting the dip switches very easy. Just go to kawasaki.com and click on the bike you have and click on accesories and you will find out the info on one of the tabs on the left of the screen next to all the tabs for accesories.(sorry i forget what they are) If you need any help PM me
BlackNinjaZX6R
09-13-2007 03:33 AM
BlackNinjaZX6R
08-23-2007 02:15 AM
TMAN
06-08-2006 06:22 AM
gotrice
11-02-2005 04:01 AM
gotrice
08-15-2005 06:22 AM
Quick Reply: Just got my speedohealer....
