JUMPER WIRE MOD
Old 12-21-2006, 08:18 AM
shinobi636's Avatar
Default RE: JUMPER WIRE MOD
I'm wondering if the mod will change the "max HP" point in the power band? I think stock you achieve "max HP" at 11.5. If it changes the mapping above 8K then it should. When you do the mod you should have the bike dynoed to see where the knew power band is. Thinking about this is making my brain itch.
Old 12-21-2006, 10:24 AM
MeansGo's Avatar
I knew it'd be too good to be true.
Old 12-21-2006, 02:21 PM
mikedrinfla's Avatar
Heres my dyno with out the wire mod. Max HP around 12.5 RPM. SPEED I might be doing the mod after christmas. I will keep you informed.
[IMG]local://upfiles/3581/E51F9297A1714595B66EDB6B8509F264.jpg[/IMG]
Old 12-21-2006, 06:51 PM
speedracer138's Avatar
You should see your redlineRPM increase by about 1500 and the HP along with it.
Old 12-21-2006, 07:44 PM
shinobi636's Avatar
Good lookin' out Mark. Speeed I think you'll end up being right. Because to just change the point that the rev limiter starts kickin' in would be dumb.
superninja600
11-09-2008 06:23 AM
xmxracer
03-17-2007 06:27 AM
rider636
11-05-2006 05:03 AM
kaggriff
04-23-2006 08:31 AM
txredneckmedic
03-15-2006 11:13 PM
Quick Reply: JUMPER WIRE MOD
