ive got a problem
well on my 05 636 im going to remove the passanger foot pegs. I already got the left side one removed (no problems)
The problem is the right passenger foot peg (closer to the exhuast pipe)
It just wont budge! and yes i have the right tool.
I even put some of that oil stuff that losens bolts or whatever, and still nothing!
I dont want to strip it because i think i might be almost @ that point. ANybody have any advice? [:'(]
i had this problem with some of tha bolts also- im not too sure if you should do this, but when some of them looked as if they were about to strip, i got my screw driver bits and stuck in the one that fits real tight in between- does that make sence?- i used a big screw driver head- but it got to be real tight to work, or it'll just strip more- hope this helps
I had a problem with mine too. My pipes are uder tail but I had a problem getting the bolt out near the brake fluid reservoir. One came out easy so I torqued down on the foot peg itself and it broke loose the other bolt and it came right out. Might work for ya.....
hunterhenderson
07-22-2010 01:01 AM
kx slaughter king
09-17-2008 04:18 PM
