Info Needed Cam Chain Specs 2003 ZX6R
Old 03-06-2008 | 09:41 PM
Crasher986's Avatar
Default Info Needed Cam Chain Specs 2003 ZX6R
I'm wondering if there is a spec for the Cam Chain Tensioner length. Like if it is extended "X" mm, then the chain needs to be replaced due to excessive wear. Anybody know the answer? I don't have the manual, unfortunately. Don't even know if that is in the manual. Mine is a 2003 636.
Thanks,
Kevin
Old 03-07-2008 | 03:52 AM
speedracer138's Avatar
Default RE: Info Needed Cam Chain Specs 2003 ZX6R
You won't be able to accurately measure the tensioner length because it is spring loaded. I checked the 03-04, 05-06 and the RaceKit manuals but did not find any cam chain wear specs or limits. Seems that when the engine needs a rebuild, the cam chain gets replaced. As far as the tensioner, go to www.onesecondfaster.com and buy the APE tensioner for $39.95.
Old 03-08-2008 | 03:18 PM
Crasher986's Avatar
Thanks for checking into the specs for me!
Actually, if you take out the spring before removing the CCT, it remains where it was in the motor. Also a good starting point for when you are installing a Manual CCT. Gets you in the ballpark. One of the other forums posted a few complaints on the APE leaking oil. The Kawasaki Manual CCT is supposed to work better, and costs less.
What the heck, I might as well get a new chain. Going to tear down the head anyway...
Old 03-08-2008 | 03:53 PM
The Factory Race tensioner is $70 and is better but you can put thread sealer on the APE ($50 or less)to keep it from leaking oil around the adjuster bolt. Also, you'll hve to split the cases to replace the cam chain because there is an aluminum chain guide cast into the lower case that will prevent removal of the chain.
Old 03-08-2008 | 05:06 PM
Crasher986's Avatar
Well crap. I had the cases split last year to rebuild the transmission.
miniman
03-15-2015 12:27 AM
TweakInSleep
09-19-2010 02:02 AM
pie4foou
03-25-2008 09:46 PM
betterpix
02-27-2008 11:51 AM
Remy
05-28-2007 02:25 AM
Quick Reply: Info Needed Cam Chain Specs 2003 ZX6R
