hot frame
Old 08-01-2006, 05:34 AM
speedracer138's Avatar
Default RE: hot frame
What do you mean by trigger temp? NS, you're sick.
[/quote]
By trigger temp, I mean at what temperature does the thermostat open up to let coolant into the engine? I know that my car's trigger temp was originally 215 degrees, which was done by the factory to help lower emissions. A common performance mod was to replace it with a 180 degree thermostat. The cooler engine ran better and had a longer overall engine life.
What I would like to know is if the same theory can be applied to my '06 636, allowing it to run cooler in traffic, and possibly improving performance. Thanks.
[/quote]
It's kind of a give & take when running the cooler thermostat. On the Iron head cars it's an advantage but on the Aluminum heads like our bikes it becomes a disadvantage. You have to keep the combustion chamber hotter for a good burn because Aluminum dissipates heat much better than Iron heads. However, there is a power advantage of getting a cooler intake charge. I don't know what temperature the thermostat opens at but will find out. Most newer cars are 195 degrees F. My bike runs on the average of about 180- 190 on cold days, so it's probably a 185 or ?.
Old 08-01-2006, 10:17 AM
markmeinteil's Avatar
Speedracer is absolutely right on the aluminum/iron head temps. There isn't much of a need to buy a lower temp thermostat unless you did some heavy mods to your engine. Keep your temp within the manufacturers specs. Your engine parts were meant to run most efficiently from thermal expansion at a certain temp range. For instance, if your engine always runs cool from an aftermarket T-stat, the pistons and rings may not expand enough to properly seal against the cylinder walls, raising oil consumption and blow-by.
Old 08-01-2006, 08:01 PM
gsims's Avatar
Lemme know when that LA ride goes down.
DAMN, that IS a hot frame!!!
Old 08-01-2006, 09:23 PM
Notstock's Avatar
I think we need more pictures of that frame that evil posted earlier so we can make a batter call on this one.
Old 08-02-2006, 01:12 AM
gsims's Avatar
Yes. I definitely need a frame like that on my bike....now is that stock? 'cuz it looks aftermarket...
Old 08-02-2006, 02:42 AM
evil636's Avatar
Knee Dragging Pimp
ORIGINAL: gsims
you got it man.
ns, i can totally do that, i just dont want to get in trouble.
Old 08-02-2006, 03:50 AM
How's this frame; definitely aftermarket.
[IMG]local://upfiles/1485/64400AD556CD41CEADBEA6E2C621915A.jpg[/IMG]
  #28
Old 08-02-2006, 03:53 AM
evil636's Avatar
Knee Dragging Pimp
all hail veda g yo ! [sm=hail.gif]
  #29
Old 08-02-2006, 09:52 PM
gsims's Avatar
Nice rearset there Speed!
  #30
Old 08-03-2006, 04:54 AM
skweekie's Avatar
Evil, shame on you for making that poor little banana hold up that sign that HAS to be at least 200x its size!!!
Give the little guy a rest already!! (heheheeee)
Quick Reply: hot frame
