hitting it hard in second....
an the bike slips/jerks.(by the way this was the first time i have ridden this since i have had it) It almost feels like the chain is slipping but i don't think it is. i parked it and noticed the back sprocket moves a little before the wheel moves is that right? sprocket's not loose the bolts move with the sprocket it's like its something in the hub. I am not sure if this is going to be a transission problem or if it is the hub on the back tire or what?
not sure if i should post this in the tech section or not
RE: hitting it hard in second....
There are supposed to be rubber dampers inside betweenthe hub and the wheel. Maybe they are missing or deteriorated. Check the condition of the sprocket & chain. Replace or adjust as necessary.
ORIGINAL: speedracer138
