Help with clutch/shifter
Old 10-05-2007 | 02:24 AM
05ZX6R's Avatar
Default RE: Help with clutch/shifter
Sounds like it's time for a new clutch. How many miles on the bike, stock clutch I presume...
Next time you do an oil change, go with a heavy weight oil like 20W40 or 20W50. It won't harm anything by using this heavier oil but you will notice it takes a little longer to get up to full operating temp and you may lose 1/4 hp or so.
Also don't ride too much in temps below 32 degrees Farenheit with the heavier oil, but that shouldn't be a problem now should it.
Old 10-09-2007 | 04:46 AM
hoehoho's Avatar
i had the second gear at around 10k rpm and it pops out to neutral - anyone thoughts?
Old 10-09-2007 | 06:01 AM
speedracer138's Avatar
Go to factorypro.com and see if they have a shifting star for your bike. Sound like you need to replace a couple of gears though.
Old 10-10-2007 | 04:18 PM
hoehoho's Avatar
I drained the motor oil - looks good and no metals - The only time the grinding happens is when from 1st to 2nd or 2nd to 3rd - so would this eliminate the shift fork from having problmes because it only happens on 2nd gear so bascially the i need a new 2nd gear?
Old 10-10-2007 | 04:34 PM
BlackNinjaZX6R's Avatar
somethin could be lose
norsseman
04-07-2021 05:06 PM
Egon
KLR250
02-03-2014 05:35 PM
lrkellogg
05-01-2011 04:32 AM
jamieislimegreen
Ninja 500R
03-16-2007 11:41 AM
wiesel 112
05-23-2005 08:53 AM
