Help with clutch/shifter
Hey guys - i have a big question. Recently I have noticed that whenever I slowly shift from First gear to Second gear - there would be grinding noise - also from 2nd to 3rd gear. But if i were to shift fast - no grinding noise. I have a 98 zx600e. The thing is that when i accidentally downshifted from 2nd to 1st - with the clutch still in - there was grinding noise too. Is this suppose to happen - cause I'm not sure downshifting from 2nd to 1st with the clutch still in would cause grinding noise - is my 2nd gear goign???? Thanks alot.
RE: Help with clutch/shifter
Adjust your drive chain and if it doesn't improve, your 2nd gear could be going out and they aren't meshing/ engaging fully. Check you engine oil for metal fragments, dustor shavings.
