head gasket question
So I picked up a new head gasket for when my head is rebuilt and ready for install and one area looks different than the old. There is an oil passage that leads through the head and into the cam cap. The old gasket is fully open, but the new one is mostly solid over that passage. Its only the middle layer of the gasket, and there is only a small hole in the center.
I'm wondering if it is a mistake in the manufacturing, maybe I'm supposed to punch it out,or maybean update in design?
Any ideas?
Pics:
Overall view
Close up of original gasket
Close up of new gasket
Any ideas?
Pics:
Overall view
RE: head gasket question
You would think that a gasket would not be meant to restrict anything going through a machined hole. If it were my gasket I would just cut the hole out to match the machined hole. Gaskets aren't meant to do that kind of job. If you leave it like that my thought is that you'll end up with gasket material floating in your engine because it got broken down by the heat and constant pressure from the oil trying to flow through that hole.
Edit: Just to reiterate.. That is just what *I* would do. I don't want to say that's what you should do because I'm not gonna take any blame for this. BUT, if it was working fine before without the restriction, logic would state that it would do the same if you made the new with the same hole.
I called Ron Ayers Motorsports today and got them to call Kawasaki. No real answer from Kawasaki. The Kawi guy said that he wasn't aware of any changes in the part. His suggestion was to order another and see what I get. The Ron Ayers guy said I could go ahead and punch it out to match the original if I was concerned about oil flow. I actually am concerned about oil flow, strangely enough! Any reason you could think of where resticting the oil to the cam cap would be beneficial? Boosts oil pressure below it, I would guess... Onceoil gets into the top of the head, I suppose it wouldn't need much pressure. Just needs to get there. I honestly don't know, I'm hardly a mechanic. Just like to take broke stuff apart and put it back together fixed.
Restriction of oil flow will lead to higher pressure below the gasket and possible gasket oil leak. It's better to have ample supply of oil to the cams than not enough. Punch or drill out the hole bigger.
