having issues with key lock
RE: having issues with key lock
my buddie had to have his ignition replaced. and we watched the guy have a hell of time getting his ignition out. put a towel over the tank when doing this. this guy ended up scratching my buddies tank.
I'm thinking its going to be a headache to remove. I'll wait till the weekend to do it. I dont want to pull it and have to leave the bike with no ignition over night in the car port.
toatally. my buddies bike was parked in his carport when some one tried to hotwire it, F'ing up his ignition. that was the reason he needed to replace it. good luck with that azs, if you need some help hit me up.
I'm going to stop by the kawi deal across the street from my job at lunch to see if they can get me another key. I don't have the key number but I do have one of the original keys the vin and all that fun stuff. Maybe my key is some how worn or messed up and thats causing the problem. If that doesn't work then I will remove it try cleaning it. Last resort would be buying a new one. I don't want to have to have 2 keys one for the gas cap and one for the bike.[:'(]
ok i got a new key. still same problem. but i was able tonorrow it down. so when the key is in lock left it will turn to the off postion withe no problem i can go from lock to off all day no issues. it turns from left postion off to on easy also but, it wont go from on to the left off postion.
Sound like the tumblers inside the switch is sticking or bent. Someone may have tried to steal your bike and stuck a screwdriver inside the ignition and forced it. You can take it to the dealer and they can replace the lock barrel and cut tumblers so the original key will fit.
Get an alarm!
Get an alarm!
before I went to high 36 it did it once or twice but after trying to turn it like 2 or 3 times it would turn all the way. Then when I went to 36 it got really bad. I am in the process of trying to find a new ignition lock and gas lid so I can still use one key for them both.
