Fully Synthetic Oil
#34
RE: Fully Synthetic Oil
ORIGINAL: speedracer138
No that is not true. I spoke with the Motul rep and he recommends only their motorcycle oils for bikes due to the wet clutch. Motul has full sunthetics for bikes with wet clutches. He doesn't recommend the Auto Synthetic oils ( He only sells Auto Oils by the way, but gets me the motorcycle stuff) due to the lack of additives for the wet clutch. I have used Valvoline and Mobil1 full synthetic oils without any problems but then, I am not in racing conditions. I have over 10K miles on mine and am due for an oil change.
ORIGINAL: Humtek
I add Motul Semi blend in my 636. I was told the full syn is not good for our bikes because of our wet clutch, is that true? Also about the rear stand... if you have frame sliders installed use the orginal bolts that you removed and put them in the threads in the swing arm and use regular jack stands. Easy as pie. Don't forget to remove them when your done though.
#35
ORIGINAL: lemac
do what???? strain until 5k or strain at 5k or are ya bs n????? Explain please
Replace filter, after straining the oil after approx 500 miles. Still a new ride so far on the 10, but the filter change after clutch break in.
#39
I stumbled across this old post about the oil .I recentley changed from the Kawai brand to AMSOIL synthetic .The problem is the engine is much noisier than before . I chnaged it at 3000 and have run it now for a little over 200 miles .Did you experience this when you change to the AMSOIL SYN ? I am in eastern Tennessee and I am guessing our climates are fairly close , what weight did /are you use / using .
nomad2007
06-14-2008 04:38 AM
