FULL SYNTHETIC.
Old 05-24-2007 | 10:56 PM
aszrael1266's Avatar
The Dude
Default RE: FULL SYNTHETIC.
I'm almost due for another oil change. I think I'll give repsol full syn a chance.
Old 05-24-2007 | 11:47 PM
Bluebeast's Avatar
aszeral i got it at cyclegear and if i rember right it's on sale now. so you might get it for cheapper that i did. oh by the way that 60 dollars was with a k&n oil filter too.
Old 06-02-2007 | 05:00 PM
nodakawa77's Avatar
I have 70 miles onboard and waiting for the RP to arrive. I also bought a magnetic drain plug. Won't ride it untill the oil is changed.
Old 06-02-2007 | 09:12 PM
afboundguy's Avatar
I've been reading up on the synthetic oils and had a quick question. I have almost 10K on mine. Should I stick with the same oil or is it ok to switch to synthetic? I read in one of the post that if you have too many miles it might actually mess up the engine if you switch to synthetic. Thanks for all the help
Old 06-02-2007 | 10:45 PM
nodakawa77's Avatar
I heard things that if you put synthetic, you can't go back and stuff like that. Synthetic just sound better to me and there's a lot of oppinions out there.
Old 06-03-2007 | 08:02 AM
speedracer138's Avatar
ORIGINAL: afboundguy
Not true! Switch now.
Old 06-03-2007 | 11:07 AM
afboundguy's Avatar
sweeeeeeeet i'll switch next oil change... which might happen to be rather soon, it sucks cause i just did a normal change about 500 miles ago... o well...[8D]
  #28
Old 06-03-2007 | 11:28 PM
Bluebeast's Avatar
the thing about syntic oil is once you change you have to stick with synthic oil unless you get an engine flush. but after you feel the difference with syntic oil you won't want to change back
  #29
Old 06-07-2007 | 07:56 PM
EBDBoudreaux's Avatar
Newbie question here.
I heard the full synthetic will cause ur clutch to slip. Maybe this is just mumbo jumbo???
  #30
Old 06-07-2007 | 09:31 PM
ORIGINAL: EBDBoudreaux
Not True; just mumbo jumbo BS. Unless your clutch is worn really bad and on it's way out, then it will slip.
Quick Reply: FULL SYNTHETIC.
