Full exhaust or slip-on? Sprocket change?
i'm adding a power commander III. and i was curious, is a full titanium exhaust worth the price? or should i just do the slip-on.
Also i need more torque for take-off but i don't wanna loose the top-end. Because over here in germany i actually make it to top-end. so what would be the best sprocket change i should do.
was gonna do a -1/+2, but i heard that you top out at like 140. and i need more topend. so i was wondering should i go just +2 on the rear and leave the front at 16 teeth?
if you go with a full titanium exhaust your going to take off a lot of weight off the bike. Which should make it a little faster along with the horsepower gain of the exhaust. As for changing the bike to a -1/+2 like you said your going to lose the top end. I'm not to sure on what you would need to get it to the set up your after.
I went up 3 in the rear and still lost some top-end. Any change you make to the sprockets has some consequences. Remember the "opportunity cost" thing from econ? Same scenario...
What kinda riding you doing?
Street-Drag,Track,Stunt'n?
That will tell you what kind of system you want and sprocket set-up.
If your getting a PCIII then you must want a Full, You dont really need a PCIII w/slip-on.
My stock gearing was 17-40 I changed to 16-41 and love it I also got a speed-o-healer to correct my speed reading. I dont miss the top end cause i can barely hit 170+ for more than a few seconds round here
well see thats the thing its gonna be more for street drag but with the autobahn over her you ample times to hit over 160 easy. i was thinking of just going up 2 in the rear and leave the front at 16.
the full ti exhaust is def worth the money you will loose alot of weight off the bike and with a pc111 you can gain some nice power from the full exhaust, also -1 +2 is a nice sprocket change and still streetable by most riders you will loose alittle topend but will pull lovely down in the bikes low-mid range power
