Front Suspension
Hi everybody,
Read reviews on 636, as you know they say only weakness on 636 is front suspension. Would you know where i could read about adjusting front suspension? I have '02 636. Thanks alot.
Kailys
Kailys
Atually, the biggest weakness is usually the rider, but here is a great write up on suspension....
http://www.sportrider.com/tech/146_0402_susp/index.html
The 03's were too stiff for the street and more set-up for the track. Try backing out all the pre-load. Actually set-up your sag as in the article.
ORIGINAL: Ninjalikeboi
i assume this is also on the 03 zx6rr speed?
do you think that it was worth changing to a 05-06 suspension? also, did you just change out the rear shock or the front also? i can get a rear shock from a 05 for about 50 dollars and was wondering if it would be worth it, i never see the track only street
