Front Brake Line question
I need a longer front brake line due to my streetfighter conversion. So I've been looking around at different configurations and noticed our bikes (mine, 05 636) come stock with a double banjo bolt coming from master cylinder. So my questions is would it be benifical to run 2 lines straight from the master cylinder, one going to each the right and left side?
are your lines stock ? i know on mine, its a single off the master and a double banjo into the break side caliper and the cross over. you can run a double at the master and one line into each caliper, thats how i did my zx7
Take a look here.
http://store.58cycle.com/category_s/2996.htm
So beside from making it eaiser to bleed the air out, perfromace wise is it any better?
I feel the 2 single lines are better just because they are easier to bleed. Some people say the they supply equal pressure but it's a hydraulic system so the pressure is equal throughout the system anyway. All racebikes use 2 single lines going from the master cylinder directly to each caliper. I think all the aftermarket stainless or carbon braided lines only come that way.
