fron and rear tire
fron and rear tire
so I havea question
I’m going to go with the 120/70-ZR17
and on the rear is going to be 190/50-ZR17
had anyone try this set……. do I have clearance on the rear I read that on the front there is no clearance problem but I don’t know on the back
thanks in advance
thanks in advance
RE: fron and rear tire
well why are you changing the tire size for the rear tire anyways??? why not stay with a stock size???? the 2ct are recommended along with the pirelli and dunlop...it is usually your taste and feel of the tire...if you think that a bigger rear tire will help you out...it might just do the exact opposite!!! changing the geometry of the tires will change the overall geometry of the bike...
bottom line if you have to do this...then make sure your suspension is correct and make sure your not bottoming out...but yes i think you will have enough clearance...
Well I got this tires from a friend for good price they are diablos corsa so I still don't know if I'm going to put them on yet if I'm going to have to much trouble any other suggestions
86gpz1000
04-17-2010 05:06 PM
