FNG with an 06
FNG with an 06
New here, but not to bikes. I am in the process of prepping an 06 636 for track only use and am curious as to what most of you are doing when it comes to the exhaust flapper when going with a pipe? How are you getting rid of the FI light on most of these bikes?
Yep, go nna do a bunch of searches on past topics as well, but wanted to introduce myself here! I am not just another inexperiended rider asking stupid questions and will be looking forward to contributing here as well! I love doing track days (Current track bike has been an 06 CBR 600RR) and riding back roads around my area!
See you on the road!
RE: FNG with an 06
there is a little control module under the seat that you have to block from turning all the way around. i have also heard of ways to do it electronically, by tricking hte comp into thinking that whole system is still in place but i dont know how to do that one, i think if you call the exhaust manufacture they can tell you
have fun out there at the track, wish we had a track around here
RE: FNG with an 06
Where you located? I have two tracks about two hours either way, so it's not too bad!
Thanks for the info. Will check into the "trick the ECU" deal too since I would like to pull the whole module for weight savings if I can get away with it.
RE: FNG with an 06
ORIGINAL: meanstrk
You talking about the jumper wire trick or one on how to completely eliminate the whole valve module?
RE: FNG with an 06
no not talking about the jumper trick, no i have never done the ecu valve trick because i didnt need to my leo vince came with the valve rotor replacement. but my buddy and his gsxr with a micron did it. called up micron and they told him exactly what wire to cut and splice to compleatly eliminate the whole system and not have the fi light come on
