Engine not returning to idle correctly
RE: Engine not returning to idle correctly
Thanks I will try that this weekend. I did mess with the idle speed adjuster and lowered it to what the manuel said 1100 +_ 50 Rpm and that seemed to help the slow idle drop at stop but the jump of rpm when I cold start it is still there. Does any one ever use "Sea Foam" I've been adding it to my gas to try and clean the fuel system up. Has anyone had a bad experiance using it?
During cold start the idle should be high because you are adding extra fuel/ less airwhen you put the choke on. I have heard onlygood things about Sea Foam.
Israel-klx250s
03-04-2012 08:33 AM
