didnt start the first time...
alright so i decided not to use the caps lock anymore...but anyway i tried starting my bike the other day but it wouldnt start. At firstI waspushing the start button and it sounded like it was going to rev. I shhook it around walked it up on neutral since i figured it was sitting for 2 weeks. i then got on it and tried starting it but again it wouldnt start. It actually was makin a clicking noise only like once. It made the clicking noise once andit wouldnt do it agianuntil i took my finger off the start button and pushed it again.. Anyway i was suppossed to spend my afternoon turning on my bike for the first time but it didnt start at all so i gave up. I called the guy that sold it to me but he said it never gave him that problem. I called kawasaki and they said it is showing signs of a dead battery. i figured i let it rest and try antoher day to figure it out...any advice or ideas from any of you guys would be appreciated ...thanx.
from a determined rider who wants to ride his new bike already.....!!!
RE: didnt start the first time...
Charge the battery and you will be good to go. Also, if the bike is going to sit for more than a few days, put a battery tender on it to keep the battery charged. You can get them for less than $20.
Also, if you really want to ride right away or you are stuck somewhere with a dead battery, you can pop start it. Just put it in 2nd gear, put the key in the ON position, get a rolling start on pavement and then let out the clutch while giving it a little gas. It should turn over and you can quickly pull the clutch back in so it doesn't take off.
The battery shouldn't go dead in 2 weeks. You may have a loose or weak battery connection. Take off the terminals, clean them with a wire brush and re-install.Fully charge the battery before re-installation. Poor connections can lead to the battery not charging or slowly dischargingand it will cause a film of oxidation to form between the battery & terminals. It happens more when it's really cold and if the bike isn't ridden for weeks at a time. You can buy a battery tender/ maintainerfrom harbor freight or on ebay for about $15 or less. I have seen them as low as $7 at Harbor freight.
ORIGINAL: speedracer138
kawaklx
07-08-2009 03:41 PM
rayw1128
06-06-2007 03:10 PM
