Deceleration pop?
Old 03-25-2008, 01:54 PM
Default RE: Deceleration pop?
pfft then wear your green gloves problem solved[8D]
ORIGINAL: evil636
who cares it sounds cool mine does it all the time with and with out the pc hooked up to it. and only when its cloudy but above 70 degrees and the front tire pressure is at 28 lbs instead of 32 and when i wear my black icon merc gloves.
Old 03-25-2008, 07:40 PM
evil636's Avatar
Knee Dragging Pimp
i knew there was a catch [>:]
Old 03-25-2008, 08:23 PM
adramalech's Avatar
well from what i have heard and come to understand if the fuel to air ratio isn't really close to nominal then you will either a. not get the total performance boost from your aftermarket exhaust..pciii or any other intake mod you can perform... it is really only comes to problems when it is overly rich or lean...alittle over either way won't hurt much...but if you like me and had it way to rich (on accident!!!) then there comes the back fires which will hurt engines!!![]
if you don't have a really altered map don't worry about it...but if you are running like high octane fuel... or full exhaust might want to check it out...on the map that is..
Old 03-26-2008, 12:50 AM
TORA's Avatar
Hey, youre probs are because of smog if its still all connected,
Old 03-26-2008, 03:13 AM
OMalley912's Avatar
Yeah, not sure about that. I'm 40 minutes outside the city that doesn't have much of a smog problem like. Being an enless winter it seems, the air had been super crisp and chilly. It's so barely noticeable.
Old 03-26-2008, 05:40 PM
TORA's Avatar
Naw bro the smog system on the 636 causes the pop, do the pair mod from another thread and this prob wont happen anymore!
Old 03-26-2008, 08:02 PM
OMalley912's Avatar
Cool thanks, as soon as the weather breaks for good I'm gonna run it hardcore and see what's going on. When I change the plugs soon I'll print out the mod and do that while it's apart.
Old 03-26-2008, 10:44 PM
RizinSun's Avatar
You will most likely have "pops" here and there during decel as it is pretty common with our bikes. I noticed that you have a PCIII installed too as well. If you want less "Popping" then a custom tune is in order. Also when was the last time your plugs were changed? I'm not saying that the change of plugs will stop the popping issue all together, but it has helped in my case where the "popping" wasn't as frequent. Best of luck to you.
IL
Old 03-27-2008, 02:57 AM
OMalley912's Avatar
Had it out today and it was run like it should be. Didn't hear any pop other than the normal deceleration. Just turned alittle over 6K so plugs are a must 'cause i don't know when the first owner had them changed or if he did. Might just be all in my head getting used to the hearing the new exhaust too. But all ideas are appreciated.
ianmcdca
05-07-2015 10:50 AM
ThatRat
06-02-2012 10:54 AM
Paul442
KX250 & KX250F
02-01-2008 04:00 PM
Zen Dude
01-14-2008 01:23 PM
skylinegtst
04-01-2007 02:45 AM
Quick Reply: Deceleration pop?
