CR9EK
RE: CR9EK
C = 10 mm
R =Resistor Type
9 = Middle Heat Range (Range from 2 (hot)-11(cold))
E = Thread Reach 19 mm (3/4")
K = 2 Ground Electrodes
I am not sure what you are comparing the plug to but the info above came out of my NGK Book at the Shop...hope it helps.
R =Resistor Type
RE: CR9EK
ORIGINAL: suprakawigrl
C = 10 mm
R =Resistor Type
C = 10 mm
R =Resistor Type
RE: CR9EK
ORIGINAL: fask
CR9EK
what is the deal with this plug? Is it hotter or colder or the same?
What is the power gain on a stock engine?
Are the gains tried true and proven?
Why does it make more power?
CR9EK
