chain lube to cure a squeaky front wheel?
RE: chain lube to cure a squeaky front wheel?
Yeah, check everything and if you have to put on graphite of even silicone spray, try not to use too much or get any on your rotors. You can try spray Moly Lube like Dri-Slide.
every thing is dry :-( bearings gone not slack but stiff spots during rotation im getting new bearings but i gota wait for em to come in guess it'll give me time to screw with the god awful looking fairings oh yea i found a way to get the wheel off without the kali front wheel removal tool,, takespark plug socket turnd backwards and insert the extension in the wrong side fits perfectly in the axle nut thing
My bike just hit 3K, and started squeaking up front. In my case it was brake crud. Before taking the wheel off try cleaning the rotors, and scotch briteing the pads. 'cause the warranty ain't gonna cover maintenance issues like brake crud, or glazed pads.
