CF wind screen and cowl
RE: CF wind screen and cowl
i have also been looking with no luck, i know puig makes an ok looking fake carbon screen. since i havent been able to find any i was going to try to make one on my own, it really isnt that hard to make some, ill let you know how it goes
Hey Sup,
You ever worked with CF before? Let me know. I have seen some CF windscreens and Cowls. Check with www.OPPracing.com .
ORIGINAL: speedracer138
Hey Sup,
Hey Sup,
yeah he is right pretty much same as fiberglass, main difference is you use epoxy resin instead of pollyester resin, (clear vs. odd brown color) but yeah just create a mold and then you need a releaser on the mold (vasalene, pam, etc) then resin then lay your carbon more resin carbon resin carbon etc. let it dry pull it out of the mold then wet sand and one more coat of resin on the outside or clear coat if you are in a hurry, stuff turn out pretty good just doesnt look like the expensive carbon cuz i dont have a vacume sealer so there are a few bubbles, which normally come out in the wet sand
