Brake light Hard on...
I have a 05 636. Put on Dual two bros exhaust and its fender eliminator. I also have a scorpion alarm system and it connects to the turn signals. When my alarm was acting up because I had swapped two wires on the turn signal, then fixed it and alarm good, but as stated, my brake light is hard on. For some reason after installing it, by brake light is hard on. Only in parking is the tail light on and brake off. Fuses good, disconnected the turnsignals and license plate light from connectors( in case had wiring mixed up or a ground), then saw no fix so took fuses out for turn signals and head light and still. Brake light is hard on. Tail light should be on when bike on and brake on only when braking with pedal or hand, correct?,Suggestions?
funtoos
03-28-2006 10:04 PM
BigRig18Wheeler
03-06-2006 09:39 AM
