blinker problem
blinker problem
okay maybe hard to understand so ill explain as good as i can. i push my blinker switch to the left and it returns to the middle like it should and the left blinkers work. so i push it to the right but the switch doesnt go all the way to the right but it DOES cut the left blinkers off but the right blinkers dont come , neither does the green arrow on the dash. i have LED blinkers so im sure there not bad. i checked the signal fuse and there ok. my blinkers are all hardwired into the factory wire system. what could be the problem
RE: blinker problem
lol^^^ well if the switch is bad you could take it apart and try cleaning it with some contact cleaner or rubbing alcohal and see if that helps. you can't F it up anymore then it is. wait!! have you checked the fuses yet?? relays??
RE: blinker problem
took apart the switch and i guess it was stuck, i moved it around and now it moves left to right easy and the blinkers work. headlights still dont. i check everything but relays. which one is for the head light and how do i check it.
