anybody??
anybody??
I looked around quickly and couldnt find it, but has anyone installed Pazzo levers? if so, is there any trick or is it self-explanatory?? I got the silver ones with black tabs plussilver ZX grips from 58cyleand silver 1.5" bar ends
RE: anybody??
to install my grips i used contact solution. If you want to remove and save the old ones just get some solution under the grip and twist off. DONT STOP twisting. If not just cut them off.
Putting on the new ones will require alot of solution and twisting. Just use s small screw driver to lift the grip up and squirt in some solution and twist till you get it.
Also do it when you are able to let it sit over night. THis way it can dry out. No grip glue is needed.
RE: anybody??
yeah santa was good, brought me the grips and levers...bought myself the bar ends, almost bought a Hyperpro damper today, but i figured id wait until i paid off my credit card, and when I can ride again
RE: anybody??
I already put the same grips on and am going to put on silver shorties w/ black tabs tonight. The grips were a piece of cake just follow the directions that came with them and they're easy. I'll let you know how the Pazzo's go. I'll take some pics and post them up if you want.
