antifreeze on the ground :(
Old 04-15-2008 | 12:31 AM
Jacked's Avatar
Default antifreeze on the ground :(
So, I just bought my 03 ZX6R last fall, and I noticed every once and a while if I start up the bike, and let it get up to temp w/o taking it out (mostly keeping everything lubed up over the winter... but also so I can listen to my new baby purr...) and then kill the engine I'll come back to the garage a couple hours later and there will be a small puddle of antifreeze on the ground... It only does this periodically, so it can't be a leak, that means it is most likely comeing from the overflow tube... but I don't think it should do that unless the engine gets above normal operating temperature right? and why wasn't it designed with the overflow tube refilling the resavior???
Old 04-15-2008 | 02:20 PM
zzrick's Avatar
Default RE: antifreeze on the ground :(
Make sure the clamp where the hose meets the radiator is tight, mine did the same thing for a while, I tightened the clamp when I got a chance and no more leak. Oh, and use a small ratchet or wrench, screwdriver wouldn't get the job done for me
Old 04-17-2008 | 03:42 PM
Jacked's Avatar
I'll check that out... thanks!
Old 04-17-2008 | 11:19 PM
speedracer138's Avatar
Yes, there was a service bulletin for the 03 ZX6R/RR's for loose hose clamps causing leakage. I ad the same problem with mine. Just inspect and tighten it.
PALYDIN11
10-25-2006 08:11 AM
dedbrok
08-11-2006 03:15 AM
Cold Iron
07-24-2006 09:47 PM
ZX12Rider
02-03-2005 03:54 PM
Quick Reply: antifreeze on the ground :(
