alternator/generator output?
RE: alternator/generator output?
22.5 A/14 V @5 000 r/min
found under General information in chapter
hope this helps! this is from an '05 tho... but should give you an idea, bro...
edit: the manual IS for an 05/06...this should be your number, sir. 1-11 under gen specs.. not sure what model you have exactly tho...
thanks w hedrix!
was just looking at heated vests/jackets... yea feel free to call me a wuss. one of the sites talks about the units not working very well unless the bike has a 400 watt generator in it. looks like i'm at 315w @ 5000. i'm sure i could get away with just a vest!
The alternator voltage outputbefore it get to the voltage regulator is up to 42 volts!! If you can get a differentregulator to work (Maybe an R1 due to their 4 headlights) you'll have plenty of wattage.
Finger Mullet
04-19-2008 02:30 PM
