acessory "hot" lead for grip heaters??
RE: acessory "hot" lead for grip heaters??
ORIGINAL: 636whoop
so are you saying its a bad idea to wire them along with a high beam or a low beam?
You can T-tap off theRED tail-light wire from the ignition switch. Check it first with a test light to see if it turns off with the switch off (It should).
The taillight wire might be a better idea. The headlight would be easier but it will only have power when that high/low lightis on. If you run it to the red taillight wire it will be powered when the key is in ON or PARK. It looks like you can run it to the blue wire to only have power when the ingnition is ON. Of course, test them with a meter or test light first. Both headlights and taillights are 10A fused so it wont be a problem tapping them for juice.
ORIGINAL: speedracer138
thanks all!
ready to go riding with warm hand today!
(it's 52 in pdx)
Actually they did that for the Euro running light that went in the top corners of the headlights but the US models don't use them.
were you then one talking about riding with litre-plus bikes in second? rad! i swear the 636 is the "little bike that could"
