2007 ZX-6R instrument cluster on a 2006?
Old 03-24-2007, 03:01 AM
sup_uni's Avatar
Default RE: 2007 ZX-6R instrument cluster on a 2006?
i think it glows like the 06 10r all white. ill see if i can find a better pic tonight or get one from the kawi dealer here. i know i have seen a better pic online
Old 03-24-2007, 09:32 PM
MSR 05 6R's Avatar
That was my first thought when I seen the 07 cluster.
Would look killer!!!
Old 03-25-2007, 12:28 AM
alexanderm's Avatar
I would have to agree, before I got my zx-6r all I could think about was how cool the digital tachwas and now after using it for a while I wish it had a bigger needle tach.
Old 03-25-2007, 03:08 AM
mikedrinfla's Avatar
One question how many of you use your tach that much to want to change it out? I usually just go by the sound. Digital analog what the diff ? And what does it matter if you are not constently using it all the time?
Old 03-25-2007, 03:31 AM
here is a link to a video of the first ride of the 2007 zx6r and you can see the tach.
http://www.youtube.com/watch?v=p10ci...ted&search=
http://www.youtube.com/watch?v=tc6SXLIAI4M
Old 03-25-2007, 03:36 AM
This is a little better
Old 03-25-2007, 08:27 AM
biglg7's Avatar
one potential problem i see with this swap is the new ones have gear indicaters so you would have to find a signal wire possiable for that which i believe is not persent on the zx6r
Old 03-25-2007, 08:38 AM
They make an after market gear indicator for the 06 zx6r. So it would be possible.
Old 03-26-2007, 06:32 AM
sup_uni's Avatar
no i dont think it would the aftermarket gear indictor runs off of the bikes power chage at any given rate and if it comes stock with one there isa definate possibility that there is an actuall sensor somewhere, but if ther eis a sensor, i dont see how it would be that hard to get a sensor and rig it into a 05 system
Old 03-27-2007, 08:42 AM
speedracer138's Avatar
Most gear positionsensors work off of RPM & speed calculationsfor the indication so if you tap into those wires, it shoul work. I would have to look at a wiring diagram to be certain.
Quick Reply: 2007 ZX-6R instrument cluster on a 2006?
