2007 kawasaki zzr has problems staying running?
I bought a 2007 kawasaki ninja zzr 600 4 months ago it ran good for acouple weeks then coming home one day from work it hesitated a bit then just died down. It was low on gas so i thought it was that until it did it again. then i changed the plugs, fuel filter, air filter, oil and filter, gas in the tank, rode fine acouple times then did it again. I then put a new battery in and used sea foam the other day, ran good all day had it up to 102 then the next morning it did it again. now its setting in my garage, it seems to do it everytime im riding steady at 55-60? i dont know what else to check, i need help..
Welcome to KF
Starting with the basics, there is a good chance that some sediment got caught in the carbs when you ran it low on fuel. Check the pre-screen on the fuel tap at the same time. http://www.ronayers.com/Fuel-Tank22-C70549.aspx
Sometimes sea foam will work as a treatment, but it works better as a preventative measure.
Ok i will try that. I tried to start it again yesterday and with the choke on it tried but then shut down again. then i put the sea foam in the tank (just alil bit) again and it start right up. sounded alil rough. but i will try that today with the tank. thanks.
