2002 636
RE: 2002 636
The same reason you see V6 mustangs with GT badges on them and HEMI badges on Ford and Chevy's. Wannabes are just that.
Here are the specs for the 2002 ZX-6R:
Engine Configuration Inline Four, 4-Stroke, DOHC
Engine Displacement 599 cc
Engine Cooling System Liquid
Compression Ratio 12.8:1
Combustion Chamber Design Pentroof
Valves Per Cylinder 4
Intake Valves Per Cylinder 2
Exhaust Valves Per Cylinder 2
Bore x Stroke 66.0 x 43.8 mm
Claimed Peak Horsepower 109 bhp @ 12,000 rpm
Claimed Peak Torque 48.5 lbs. - ft. @ 10,000 rpm
Measured Peak Horsepower 94.4 bhp @ 12,400 rpm
Measured Peak Torque 41.8 lbs. - ft. @ 10,400 rpm
Measured Power To Weight Ratio 4.70 pounds per horsepower
Engine Redline 14,000 rpm
Valve Angle (Included) 12 degrees intake, 13 degrees exhaust (25 degrees)
Combustion Chamber Volume 10.2 cc
Valve Train Type DOHC, Link-plate Chain Drive,
Bucket Followers, Shim-under-bucket
Lash Adjustment
Valve Adjustment Interval 7500 miles
Intake Valve Diameter 27.0 mm
Exhaust Valve Diameter 22.6 mm
Intake Valve Stem Diameter 4.0 mm
Exhaust Valve Stem Diameter 4.0 mm
Intake Valve Maximum Lift 9.2 mm
Exhaust Valve Maximum Lift 8.4 mm
Intake Valve Timing
Open BTDC 56 degrees
Close ABDC 80 degrees
Duration 316 degrees
Exhaust Valve Timing
Open BBDC 61 degrees
Close ATDC 33 degrees
Duration 274 degrees
Valve Timing Measuring Point 1.0 mm.
Fuel Delivery System (4) Mikuni BDSR36R CV
Carburetor Venturi Size 36 mm
Air Filter Type Dual-element Foam
Exhaust System Type 4-2-1
Ignition System Digital Electronic
Lubrication System Wet Sump
Oil Capacity 3.7 quarts (3.5 liters)
Fuel Capacity 4.8 gallons (18 liters)
Transmission Type 6-speed, Constant Mesh
Clutch Type Multi-plate, Wet
Clutch Actuation System Cable
Clutch Spring Type Coil
Number Of Clutch Springs 4
Number of Clutch Plates 17
Drive Plates 8
Driven Plates 9
Primary Drive Gear
Primary Drive Gear Teeth (Ratio) 44/ 89 (2.023:1)
Final Drive Sprocket Teeth (Ratio) 15/ 40 (2.667:1)
Transmission Gear Teeth (Ratios)
6th 26/ 24 (1.083:1)
5th 28/ 23 (1.217:1)
4th 29/ 21 (1.380:1)
3rd 31/ 19 (1.631:1)
2nd 33/ 16 (2.062:1)
1st 38/ 13 (2.823:1)
Transmission Overall Ratios
6th 5.843:1
5th 6.566:1
4th 7.446:1
3rd 8.800:1
2nd 11.125:1
1st 15.231:1
Lash Adjustment
Intake Valve Timing
Drive Plates 8
Driven Plates 9
Primary Drive Gear
6th 5.843:1
5th 6.566:1
4th 7.446:1
3rd 8.800:1
2nd 11.125:1
1st 15.231:1
RE: 2002 636
I remember reading an article in T.W.O. its a euro bike mag where they compared the 02 636 to the 05 636. I was shocked to learn the 02 came as a 636. yea its just a euro thing. sucks we never got it.
RE: 2002 636
ORIGINAL: Sprocket
The overseas version of the '02 6R had a 636. Not sure why that motor wasn't in the US bike.
RE: 2002 636
well how many miles is too many where id need to replace my engine? ive got 21,000 right now.
id love to throw in a newer 636cc in it! wouldnt that be sweet. a custom 636.......
RE: 2002 636
There is a guy who work at cycle gear with an 02 zx-6r. I gave him the copy of the issue I had. I wish i had meet him sooner. He blew the motor in the bike and wanted to put o 636 motor in it. he has another 02 600 motor but He is thinking of trying to get the 636 motor in it. My bike next to his the frames look just about dead on.
RE: 2002 636
The bike hasn't changed much since 95 except for some body/ cosmetic stuff and the motor is pretty much the 95 design including the new ZZR 600's. The 636's difference was the extra CC's & fuel injection along with the suspension & bodywork. I bet the frame measurements are almost identical; looks like it to me. I bet a 03 636 rear subframe will bolt right up.
bls5782
06-13-2005 06:25 PM
