07 zx6r front sprocket nut size?
Help going to change my front sprocket on my 07 zx6r what is the nut size a one inch fits on the outer side and an 1 1/16 fits on the inner side. Are these the correct sizes or should I go with metric mm? Thank you
Welcome to KF!
Unless you plan on turning against the chain or the transmission your best bet is to hit it with an impact wrench, in which case, you better have the metric. You may be able to get it with wit your standard sockets but that thing takes alot of torque, and you really dont want to round it out. Good luck brotha!
