'07 ZX6r fork springs? Rear spring?
Old 01-09-2007 | 11:45 PM
sithz's Avatar
Default '07 ZX6r fork springs? Rear spring?
Hi,
Does anyone knowwhat kg the fork springs will be? What about the rear spring?
I'd be interested to know since I am roughly 180lbs. The new GSXR comes with .90's which is great. Hoping Kawasaki did something similar.
Also: Unrelated question: Can the transmission be serviced without breaking the block?
Old 01-10-2007 | 12:09 AM
evil636's Avatar
Knee Dragging Pimp
Default RE: '07 ZX6r fork springs? Rear spring?
not sure on the spring rate on the 07 but the specs should be somewhere on the net. as far as the tranny, service meaning what ? if you need to go internal, you have to split the case. welcome to the forums.
Old 01-10-2007 | 07:05 AM
speedracer138's Avatar
Welcome to KF. The transmission oil is the same as the engine oil (same oil in the same case) so when you change the engine oil, you're also changing the transmission oil. Check on the first ride articles written about the 07 for the spring rates or you may have to contact Kawasaki for that info.
Old 01-11-2007 | 07:44 AM
ORIGINAL: speedracer138
Whatcha talking about Willis!!!
Fork spring .90kg, roughly 180 lbs (without gear?) with unknown wt fork oil. You could actually set your sags on the front with this number?
Old 01-11-2007 | 08:06 AM
evil636's Avatar
Knee Dragging Pimp
whats how low my pants hanging off my *** got to do with the front of thu sag main ?[8D]
Old 01-11-2007 | 08:35 AM
hahaha, prolly just a shorter inseam
Old 01-11-2007 | 09:15 AM
He had asked about transmission oil change.
Also, in the early days you had to adjust dampening by changing the fork oil weight, but now there are cute little ***** & screws to adjust that with. I think the fork oil viscosity is 5 weight. The preload is easily adjusted on top of the forks. Set your ride height and sag and you should be good to go.
miniman
04-09-2015 06:14 PM
buffalony
08-29-2008 08:12 PM
56cbr600rr
04-12-2008 03:48 PM
mudjunkie
01-26-2008 08:14 PM
