07 6r throttle plates?
RE: 07 6r throttle plates?
You cn do the ECU Jumper mod to the 07. Removing the secondary throttle plates may cause a loss in low-mid range power and a lag or flat spot in the mid range. Some people yried that on the 03-06 636's but didn't like it. The ZX10's have more power & torque so are not as affeted by removing the secondary plates. He can try it an re-install them if he doesn't like it. Make sure he removes the throttle bodies or keeps the primary throttle closed just incase he drops a screw in the intake.
