06 636 LE with Flames removed
Old 05-28-2007 | 02:02 AM
sup_uni's Avatar
Default 06 636 LE with Flames removed
well i finally did it. let me know what you guys think. i didnt like it right away and thought i had made a big mistake (new flames from kawi are like 400 bucks) but i am starting to like it
http://i58.photobucket.com/albums/g2...i/DSC02098.jpg
http://i58.photobucket.com/albums/g2...i/DSC02097.jpg
http://i58.photobucket.com/albums/g2...i/DSC02096.jpg
Old 05-28-2007 | 04:21 AM
candylighting's Avatar
Default RE: 06 636 LE with Flames removed
i like it better with the flames on, i think since you took some off, you should take them ALL OFF, then it would look better.
Old 05-28-2007 | 09:03 PM
Mott Power's Avatar
so much better, take em all off, i hated those freaking flames when they came out and still do
althought keeping those ones on looks kinda neat
Old 05-29-2007 | 02:16 AM
Bluebeast's Avatar
i would remove them all. i think the bike would look even better.
Old 05-29-2007 | 04:51 AM
sup_uni's Avatar
the problem with removing all of them is the ones on the tank are clear coated over so it is alittle harder to remove those, i thought leaving a few on the side would make it look better than all off but the tank
Old 05-29-2007 | 02:41 PM
Bluebeast's Avatar
that's true there sup_uni i for got about the flames and stuff being clear coated over on the tanks. I like the way the bike looks. I think it would look hot if you had a little bit of flames on theseat cowl of the bike too. maybe that would look better. but what ever you decid to do is up to you right. That's what makes our bikes differ from one and another. which were all trying to do right. It looks good and make it look the way you want .
Old 05-29-2007 | 03:49 PM
toad1025's Avatar
I think it looks fine the way it is, but maybe add some to the cowl. Ultimately it's your bike and you have to make it YOU. If this is you, then it works for me.
runmofo
Ninja 250R
34
06-30-2008 04:29 AM
topic7
04-19-2008 09:21 PM
TitaniumZX6r06
01-25-2008 07:46 AM
VTechKaw
01-24-2007 09:39 PM
EMS_0525
11-19-2006 10:45 AM
Quick Reply: 06 636 LE with Flames removed
