TIMING RETARD ELIMINATOR?
DOES ANYBODY KNOW FOR A FACT IN INCREASING RWHP OR TOP END AFTER USING A TRE. I'M TALKING ABOUT DOING A BASELINE RUN COMPLETELY STOCK, THEN PLUGING IN A $48.OO TRE ON THE SAME DYNO, AND THE SAME CONDITION.
RE: TIMING RETARD ELIMINATOR?
Ivans TRE will let you run on the top end. Don't know about hp. What it does is trick the emc to thinking its in 5th gear. In stock trim 1-4 gear limit ign. advance and 6th gear has a top speed limit. On my bike with our temp, it pinged off idle to about 3500 when running in town. Shifting was smoother, with TRE installed. Don't know why. I ended up pulling TRE out.
deej
02-17-2008 07:35 PM
