2004 10R Clutch resolution needed
my clutch is starting to slip really bad. It catches really late. No acceleration now. anytime I get over 6000rpms at anything past 1/4 throttle it just zooms twards redline with no real acceleration. Is there anything I can do to adjust it or something cheap (<$20) I have oil on hand so I'm not worried about removing the engine cover. I just need to get it through the next couple weeks. A new clutch is in the budget later in the off season.
if this helps, on the clutch leaver there is the cable running into it. remove the rubber cover and there should be a bolt or a washer or something that is threaded. turn one way see if it helps, if it doesnt turn it the other way. i cant remember what is exactly on this bike but every this should be fairly generic. there will be an adjustment on the clutch, 99.99% of all clutches have it, weather it is motorcycle, automotive or marine.
SickSuzuki311
09-10-2007 03:58 AM
beansbaxter
10-09-2006 11:33 AM
