LED lighting on my 650R
I bought an Electro Pod light kit for my 650 it has 6 pods and 2 light bars i wanted to see if anyone has put LED's on their's and where they put them im having some trouble with the light bars and tail section but i still want to know the all around spots if possible your help would be great.
2007 kawi ninja 650r cany sonic blue with arrow slip on
it sounds bad *** and i have heard the two bros sounds good too
RE: LED lighting on my 650R
i bought little seperate LED pods and installed individually. i put one in eacj front faring and one under the tail and adheared them with 3M double side sticky and ran the wires through the farings. make sure you fuse them even though they are LED's. here's the one i mounted in the back. http://img225.imageshack.us/img225/5133/me024lz3.jpgHere's the one i mounted in the RF faring it's basically the same as the left side. http://img225.imageshack.us/img225/4073/me029at2.jpghope that helps some. good luck!
I have white FX lights through out my bike, but they are all attached to the frame, and when the fairings are on the bike the only ones that you can even see are the few I have on the bottom of my cheetach race lower. I bought 2 of the kits that you are talking about with the light bars, and the pods. Then I bought probably 8 other sets of the pods. I put 2 of the light bars up under neath the gauges, and 2 more up inside of the frame around the engine.
