Is the 650r a good bike for a 5'1 105 lbs?
Old 04-23-2008 | 05:51 PM
sonyab523's Avatar
Default RE: Is the 650r a good bike for a 5'1 105 lbs?
ORIGINAL: Kohburn
the clip-ons are your handlebars - can provide a rise or drop inthe position of the grips.
So they can provide both or is it one or the other?
Old 04-23-2008 | 06:06 PM
sonyab523's Avatar
ORIGINAL: deej
Hey Sonya, I don't know anything about your bike, but I just realized you never got a real welcome to the site, sorry. So welcome!!!
Thank you I appreciate it.
Old 04-23-2008 | 06:09 PM
Kohburn's Avatar
ORIGINAL: sonyab523
ORIGINAL: Kohburn
one or the other, some are adjustable. i'm not familiar with what woodcraft makes for the 650.. would have to check their website.
Old 04-24-2008 | 10:48 AM
Ninja650RDude's Avatar
That's in line with what I was saying about lowering it. Great! The fact that it hasclip-on's means that the front is already lowered(You have to drop the forks in order to have something to mount them to)So all youhave to do now is get a lowered rear shock and maybe drop the forks a little more. The clip-on's are hollow so you can slide the forks up through them to any size drop you want. The forks are basically just a round cylinder so you can also rotate the clip-on's on them to get just the right swept back position that feels best for you. Or you could replace them with any 41mm clip-ons you want, if you'd like, say if you want some rise to them so you're not as leaned over. You name it, there's a set of 41mm clip-on's out there for whatever stance your looking for.
-edit-Actually I think there are two Catalyst fairings This one:
Which would not bea good candidateif you're looking intolowering the bike because it droops down and might interfere with a lowered front wheel when you're turning. Also the clip-on's would be below the triple tree so your riding position will be pretty aggresive with more weight on your wrists.
Old 04-24-2008 | 11:51 AM
Then there's the Catalyst fairing that's exactly like the stock one but is composite so it's lighter I guess. If it has this one then he had to lower the front end to get the forks to protrude up to mount the clip-on's to. You can only mount clip-on's above the triple treebecause of clearance with the stock bodywork. It's cool because you can slide the forks up through clip-on's to get the front end to lower to any height you want.
Looks like thisedit-these are the Woodcraft clip-on's)
Old 04-24-2008 | 12:08 PM
Kohburn's Avatar
these are the woodcraft clip-ons http://www.woodcraft-cfm.com/Scripts...dproduct=17275
Jonesy
Ninja 650R
16
03-20-2009 08:22 AM
twinkletoes
Ninja 650R
25
11-18-2008 12:48 PM
kx85racer
02-26-2008 11:49 PM
Nobrakes
01-10-2007 12:03 PM
incabiker
03-02-2006 03:20 AM
Quick Reply: Is the 650r a good bike for a 5'1 105 lbs?
