wiring routing
wiring routing
Does anyone have pics of how the wiring harness is routed along the bike?
I took every single wire off of the bike last year and my pics don't clearly show how the wires were run.
Thanks.
-Joe
Thanks.
-Joe
RE: wiring routing
Joey, with all this major work you're doing, you DO have a copy of the factory service manual right?
Look at the first paragraph of the supplement: "Wiring and hose diagrams."
If you don't have the manual, go get one. It will pay for itself many times over during your ownership of the bike.
Peace!
-CCinC
Peace!
-CCinC
RE: wiring routing
I suppose it might be a good idea to take a look at that book. I forgot I bought one it was so long ago. Thanks for pointing out where to find the info. When I get home tonight I'll check it out.
Thanks Chris.
-Joe
Thanks Chris.
-Joe
RE: wiring routing
I looked in the supplment and the color schematic in the haynes manual and I've got all the wiring set except for the ignition coils and a wire that has a metal ring connector (as opposed to a plug) that seems like it should bolt to something near the handlebars. Anyone have an idea where this wire goes?
Also, I have the #1 and #2 ingition wires going to the right coils, but the schematics and pictures are rather ambiguous regarding which wire goes to which terminal.
When sitting on the bike the left, #1, coil has a left pin and a right pin.
the right, #2, coil has a top pin and a bottom pin. If anyone knows which wire goes to which pin that would be great.
Thanks!
-Joe
Thanks!
-Joe
jhoffy22
06-20-2011 04:06 PM
