Raise rear part 2
Old 09-04-2006 | 11:02 AM
05blk500r's Avatar
Default Raise rear part 2
OK i would like to raise the rear and i have read all the threads and im confused. I understand its the dog bones but do you buy the whole assembly or just the adjuster plates. I read both types or something i dunno im lost.
Old 09-04-2006 | 12:06 PM
calamarichris's Avatar
Default RE: Raise rear part 2
You might as well try the easiest/cheapest fix first.
If you only want to raise the rear a little bit, why not tighten the preload on the spring first?
It would be silly to buy dogbones, adjuster plates or other aftermarket bling if simply tightening the preload spring (which you already own) will do the job.
-CCinC
http://www.calamarichris.com/
Old 09-04-2006 | 09:22 PM
05blk500r's Avatar
oh ok i didnt know if it went any higher. Like the other post but his was lowered first. Thanks though ill see what i can do with it.
05blk500r's Avatar
09klx
06-06-2010 06:09 AM
buffalony
12-26-2009 06:21 AM
Talca
Joke section!
06-15-2008 12:10 PM
mikess06
ZZR 600
08-14-2007 04:49 PM
