EX500 cam timing
Old 07-18-2007 | 09:33 AM
rz350's Avatar
Default EX500 cam timing
Hello, I had the cams out of my EX500, I don't have the manual handy, could someone with a manual please confirm the cam timing for this motor?
If I remember correctly, it's #1 cylinder TDC, and line up the marks on the cam gears, please correct me if I'm wrong!!
Thanks!!!
Old 07-18-2007 | 04:50 PM
calamarichris's Avatar
Default RE: EX500 cam timing
Believe that's correct, but I'll check the manual tonight and give you the full answer then.
If you can't wait that long, just be sure to turn the crank two full revolutions by hand before you close it up. I've seen the results of pistons hitting valves and it's uuugly.
Will reply again tonight...
-CCinC
07-01-2011 03:43 AM
LearjetMinako
07-17-2009 01:21 AM
1984ZX900
04-03-2009 03:00 AM
systemshit
KLR250
04-16-2007 07:33 PM
demonway53
04-16-2006 09:25 PM
