Dragging noise
Old 08-21-2006 | 09:08 PM
ZX12Rider's Avatar
Default Dragging noise
So I took the bike out for a little trip the other day and when I got back home, I had to lube my chain. As I'm turning my rear tire, I hear an intermittant dragging noise (kind of like metal on metal). Any other time I lubed my chain, I never heard this noise.
I'm thinking maybe its something to do with the brakes........I don't know. But I haven't really had much time to check it out. Guess I'm just looking for any ideas or suggestions to check it out.
Any ideas?
Old 08-21-2006 | 09:12 PM
markmeinteil's Avatar
Default RE: Dragging noise
sounds like the run-out on you rear rotor is making some contact with your brake pads. If that is the case, don't worry. Most rotors have a little warp to them, and will brush up against the pads every wheel rotation. You might just pull off your caliper anyway to check how much pad you have left.
Old 08-21-2006 | 09:17 PM
ORIGINAL: markmeinteil
Usually, that is correct. Place your dial indicator next to the caliper to confirm that.
Old 08-21-2006 | 09:18 PM
Notstock's Avatar
Check the chain too for proper adjustment to loose and it maybe making some noise as well.
Brake test is easy as just dragging the rear a little while you are turning, if the noise stops then check the pads.
Old 08-21-2006 | 09:32 PM
ZX12Rider's Avatar
Thanks a million for the suggestions! I was kind of worried when I got back home and heard that! I'll let you know what I find out.
Yay - time to get my hands dirty!!! (sorry NS )
Old 08-21-2006 | 09:35 PM
Notstock's Avatar
I do not mind a little dirty or lube
Old 08-21-2006 | 09:43 PM
ZX12Rider's Avatar
I think you're the one that needs the spanking!!!!
Old 08-21-2006 | 09:48 PM
Notstock's Avatar
Yes, may I have another!
Old 08-21-2006 | 10:02 PM
ZX12Rider's Avatar
As many as you can handle - if my hand gets sore - I'll break out the whip!
Old 08-21-2006 | 10:03 PM
Notstock's Avatar
ORIGINAL: bluebird
goody goody!
Quick Reply: Dragging noise
