Battery Keeps Dying?
Old 11-01-2007 | 09:58 PM
minime0616's Avatar
Default Battery Keeps Dying?
I have a 2002 kawasaki ninja 500R. My bike is in storage right now and when i go to start it everyonce in awhile the battery is dead. I was wondering if there would be anything drawing the power from it?
Old 11-01-2007 | 10:58 PM
yoman1's Avatar
Default RE: Battery Keeps Dying?
Hey Mini
make sure your terminals are clean and the battery has a good charge. your battery may just be on the way out too.
you can tell if you have a draw on the battery if you have a digital multimeter. you take off the negative battery cable, put the positive lead on the cable and put the negative lead on the battery where the neg cable goes. have the meter on the mV scale. most cars run about 20 mV so I would think it would be less than that.
calamarichris's Avatar
Five years is about the average lifespan for a bike that is not regularly hooked up to a trickle-charger when stored.
Even if you buy a Battery Tender Junior and charge the daylights out of it now, it probably won't hold a charge very well.
You can get one of these:
But once a battery starts to go, it can take other components with it, like the regulator/rectifier, fuses or switches. Replacing the battery now and getting a battery tender can avoid such problems.
Good luck and let us know how it goes.
Peace!
-CCinC
Old 11-01-2007 | 11:00 PM
yoman1's Avatar
+1
Old 11-02-2007 | 12:22 AM
exalted512's Avatar
Make sure the water level is up as well. If its not, use distilled water to fill it back up to its appropiate level.
-Cody
Old 11-02-2007 | 12:24 AM
exalted512's Avatar
ORIGINAL: yoman1
Hey Mini
This is right, aside from the mV thing. You want to see it on the ampere setting, not voltage.
-Cody
Old 11-02-2007 | 10:14 AM
yoman1's Avatar
The amperage is measured in mV, when it's less than 1 amp
Old 11-02-2007 | 11:41 AM
jeffzx9's Avatar
Like the other guys have said, if you have the original battery in the bike, it's probably time to install a new one. Just make sure when you fill the new one, you tap it on the table a few times before you start charging it. This gets the air bubbles off of the plates and avoids dead spots. A long, slow trickle charge is better than a 200amp zap, so don't get in a hurry.
Old 11-02-2007 | 10:21 PM
yoman1's Avatar
ORIGINAL: yoman1
how can anyone post something so stupid, oh that was me it's mA not mV sorry man. my bad
Thanks for the correction Cody
Old 11-03-2007 | 01:07 AM
iroc's Avatar
do we have 6volt or 12 volt batteries on the bikes?
Quick Reply: Battery Keeps Dying?
