Aftermarket Horn Mounting
RE: Aftermarket Horn Mounting
well I ordered the horn and finally got it put on bottom level with the lower triple tree clamp on a braket I made that makes the horn just not touch the headlight as it turns but my headlight is rigged in due to cracked mounting brackets,so not sure if stock would fit, took power off the starter relay mounted relay there
