zx2r
RE: zx2r
No, never even seen a picture of this one before. Is that an air intake scoop running down from the windscreen? Where is this bike from? Does Kawasaki use the same 250cc 2cylinder? I have heard some new 250cc motorcycles in different parts of the world are using four cylinder engines now.
RE: zx2r
This is what I got for the specs. The only place I know they were sold is parts of Asia and Australia. I don't know how it compares to the Ninja 250.
Capacity________________249cc
Maximum Horsepower_____ 45PS/16000RPM
Maximum Torque__________2.5Kg-m/11500RPM
Minimum Turning Radius__2.9m
Redline_________________18000RPM
DIMENSIONS
Overall Length__________2000mm
Overall Width__________ 685mm
Overall Height__________1090mm
Wheelbase______________ 1360mm
Road Clearance__________130mm
Dry Weight______________141kg
ENGINE
Type____________________DOHC 16 valve, 4 cylinder, 4 stroke, liquid cooled
Displacement____________249 ml
Bore/Stroke:____________49.0 X 33.1 mm
Compression Ratio______ 12.2 : 1.0
Starting System________ Electric Starter
Cylinder Numbering______Left to Right 1-2-3-4
Method Firing Order____ 1-2-4-3
Carburators____________ Keihin CVKD30 X 4
Ignition System________ Battery and Coil (transistorized ignition )
Ignitionm Timing________23? BTDC @ 1500 RPM
(Electronic Advanced)__ 50? BTDC @ 6000 RPM
Spark Plugs____________ NGKCR9E or ND U27ERS-N
Lubrication System______Forced Lubrication ( Wet Sump )
Engine Oil______________SE, SF or Sg class SAE 10W/20W 40/50
Engine Oil Capacity____ 2.6 L
Coolant Capacity________1.2L
TRANSMISSION
Transmission____________Type 6-speed, constant mesh, return shift
Clutch Type____________ Wet, multi disc
Driving System__________Chain Drive
Primary Reduction Ratio 3.291 (79/24)
Final Reduction Ratio__ 3.428 (48/14)
Overall Drive Ratio____ 10.076 (Top Gear)
Gear Ratios____________ 1st 2.600 (39/15)
________________________2nd 1.789 (34/19)
________________________3rd 1.409 (31/22)
________________________4th 1.160 (29/25)
________________________5th 1.000 (27/27)
________________________6th 0.892 (25/28)
FRAME
Rake____________________23.5?
Trail__________________ 84mm
Tyre size:_____________ Rear: 140/60/R18 64H Tubeless
________________________Front: 110/70/R17 54H Tubeless
Fuel Tank Capacity______15+2 L
ELECTRICAL EQUIPMENT
Battery________________ 12V 6Ah
Headlight______________ 12V 60/35 W X 2
Tail/Brake Light________12V 5/21 W X 2
Turn Signal Light______ 12V 23W
DIMENSIONS
ENGINE
TRANSMISSION
FRAME
