Valve Noise
Should you be able to hear your valves when riding? I can hear them when cruising @55mph. It doesn't sound bad loud but i can definatly hear them. Valve noise is common in these bike correct? I am @ 5100 miles and since I bought the bike used I don't know if all the valve services have been done yet. Regaurdless @ 6k I am going to get the valves adjusted.
Engines with the tappet screw adjusters like the 250R and the 500R are naturally louder than shim over/under bucket shims. It's when you can't here the tappets, that there's a problem.The valves need a specific clearance range to be safe, and when that clearance gets to zero, there will be no valve noise, justvalve-traindamage.
