Tha 100 dolla 250
Tha 100 dolla 250
yes i bought a 2000250 for 100 bucks .. but..... now im having probs.. i had the bike running.. i had to get rid of the old tank bcuz of rust..and yes i rebuild the carbs.. it has new plugs , gas tank, and gas. i bought pod filters (that havent came in yet)and it has a muzzy exhaust. ok now for the prob.. it doesnt want to crank, and if it does ... it runs for 2 secs and quits.. so i have a slight headache... it has fire ... i was thinking do i need back pressure on the carbs?...i dont have my filters yet.. ive been troubleshooting for a week.. and no i dont have the stock airbox... sorry if this is confusing to read im trying just to make sure i included everything...
RE: Tha 100 dolla 250
yes i rode it... but i had to take the carbs back off bc i had to adjust the floats.. the bike was loading up bc the floats werent closing all the way... the carbs when i rebuild them were really bad ... filled with rust from the tank.. but i think it might have something to do with how cold it's been lately.. i dunno?
coulda been some rust left in the lines if you didn't replace them. no, no carb back pressure, they'regravity fed.
got good fuel flow? could be the cold, does the choke work?
yes the lines have been replaced... yes the choke works ...im about to go out...and mess with it until i feel like kicking it over on it side...why is it on my 74 500 h1...it was sitting for like 10 plus years i clean the carbs and it runs great...im begining to think my 250 doesnt like me ...lol
I have found my 250 to be very picky about everything. I let it sit for a few weeks once and It would not run right at all. I drained the gas and replaced it with fresh fuel and it ran fine. I had to deal with carb issues for a while before I got it running right to begin with. I had topull the carbs twice, Iinstalled a jet kit, and was told I shouldn't even botherdue to problems that can arrise afterit's put in. I haven't really had any issues like that but if I were you I would get it running on it's own first then install the jet kit and muzzy because they can introduce a whole new set of adjustments and problems. I used the carb cleaning description from www.forums.ninja250.org found here, http://faq.ninja250.org/wiki/Intake It helped alot for me. I had to clean it twice before it was ok, be sure to used comressed air and carb cleaner to clean out every port, I think that was my issue the first time I cleaned it.
ORIGINAL: wannabpinki3
TIME FOR A REJET THE CARBE ARE NTO SETUP TO RUN WITHOUT AN AIR BOX its running toooooooooooooo lean you need to change the main and piolet jets!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! try that i bet it will run like a top!!!!!!! but doant waist your mony on a jet kit incres your
foozy2
01-17-2011 03:59 AM
