tail light does not work
Old 10-09-2009 | 08:46 PM
axioma's Avatar
Smile tail light does not work
Hello
I own a ninja 250 2008… now the tail light does not work. Only turn on when I use the front brake, but otherwise it does not work (not when the bike in running nor when I use the rear brake).
I don’t know the correct approach and how to solve this issue.
Thanks for your help.
Old 10-12-2009 | 11:38 AM
williamr's Avatar
Try replacing the bulb for the tail light issue. It's a dual filament stop/tail bulb.
For the brake light not lighting off the rear brake, you probably need to adjust the switch on the pedal. The owner's manual will tell you how to do this.
Rob
Old 10-13-2009 | 04:12 PM
axioma's Avatar
THANKS I replaced the bulb already and works now... for the swich Im gonna work on that.
axioma
10-10-2009 01:16 AM
IBxAnders
08-08-2008 03:59 AM
Syn
Ninja 250R
11-10-2007 09:58 PM
Ratkiller
05-03-2007 04:12 AM
